Jump to content
  • 0
ZeroByte
pre-R49 cc65 question
Question
I'm trying working to make a quick pull request to fix the YM2151 clock frequency on github (still gotta figure out how that works using the command line but not asking that here) and so I recompiled my AdLib emulation demo to see that the playback pitch is correct with my setting - but my program doesn't run because waitvsync() seems broken in cc65 on the main branch....
I don't want to update cc65 yet because I don't want to mess with cc65 at the moment because I don't want to inadvertently break my ability to write for R38 until R39 is official. Does anyone know what breaks about waitvsync() in "R39" and what a workaround might be?
I did load one of my BASIC programs that plays music, and it's correct pitch on that, and poking a concert A into the YM produced the correct pitch, so I'm already convinced, but I wanted to hear music play back correctly before making the decision to submit my pull request.
Share this post
Link to post
Share on other sites
21 answers to this question
Recommended Posts
  • 0
Posted (edited)
It's broken for two reasons:
  1. The RAM banking method changed (my version of cc65 still uses the VIA banking method)
  2. The address in BANK 0 for the jiffy timer changed to 0xa043
waitvsync() just waits for that value to change, as the kernal inc's it during each vblank IRQ from VERA.
Here's a myvsync() routine to fix it until such time as cc65 is updated:
#define time (*(uint8_t *) 0xa043)
#define rambank (*(uint8_t *) 0x0000)
static void myvsync()
    uint8_t b,j; // bank, jiffy
    b = rambank;
    rambank = 0;
    j = time;
    while (time==j) {};
    rambank=b;
Edited by ZeroByte
added what my workaround code is
  • Thanks 1
Share this post
Link to post
  • 0
Hm, wondering why it is reading the internal variable directly and depending on its location, rather than using RDTIM kernal call?
Share this post
Link to post
  • 0
Probably because it only takes around 6 cycles per loop to just CPA $a043 ; BEQ -
doing a kernal call would take tons more time. I totally get why you're not supposed to use Kernal stuff directly, but a function like this kind of makes sense, and some time in the future, the kernal will be pretty much stabilized and not change anymore except if someone wants to tinker with their system.
  • Like 1
Share this post
Link to post
  • 0
Yep!  We want waitvsync() to stop waiting, after a VSYNC, as soon as it's conveniently possible.  The ideal method would "plug" into the interrupt vector, but that way is more complex.  And, it might interfere with other interrupt handlers.  I chose to make the function small and benign.
  • Like 1
Share this post
Link to post
  • 0
True about the performance, but the kernal call would not require changes when the rom is rebuilt . Choice depends on what you value more in your use case of course !
Share this post
Link to post
  • 0
I branched the cc65 repo and started changing the cx16 lib. It now works with Invaderz and Brixx and both would now run on R39.
In case anyone wants to check it out:
https://github.com/AndyMt/cc65
I'll do some more testing myself before creating a pull request.
  • Like 3
Share this post
Link to post
  • 0
It's really going to be the viability of the cc65 tool chain that dictates when I migrate, so this is good news.
Share this post
Link to post
  • 0
Annnnnnnd it's gone!
Looks like the RTC is going to be supported now and the timej variable isn't being set in the same way - or at least the location your mod for waitvsync() uses doesn't work for me with a fresh download of the rom and emulator....
Share this post
Link to post
  • 0
I'm seeing a different value for the `.timer` address in kernal.sym than either of you with my build of the x16-rom repo on the master branch: `A03D` versus  `A043` or `A041` in Andy's repo.  There may be too many moving parts at this point between the rom and cc65's cx16.lib.
  • Like 1
Share this post
Link to post
  • 0
I just found it a few minutes ago myself. I'm going to keep using my own C rendition of this function myvsync() until R39 is finalized - I am not having trouble with anything else at the moment, so I'm going to stand pat on my copy of cc65 until R39 has been out long enough for the cc65 gurus to patch that up to match.
Share this post
Link to post
  • 0
Thanks - maybe I should use the Kernal function to get the timer value for the moment. Even though that's less efficient.
Share this post
Link to post
  • 0
Do you happen to have a Windows build of the latest r39? I could not get this to compile, I have neither Mac nor Linux machine.
Share this post
Link to post
  • 0
I've updated my Repo so now waitvsync() uses RDTIM instead of the TIMER memory address. This makes it compatible with more ROM versions, but also a bit slower. I'll change this back as soon as the TIMER address has settled.
My cc65 repository: https://github.com/AndyMt/cc65
  • Like 1
Share this post
Link to post
  • 0
This is working for me now, thanks!
It looks like there's a known issue with joysticks (https://github.com/commanderx16/x16-rom/issues/194) but I think there will also need to be updates to the joystick constants in cx16.h as they are for NES rather than SNES.  The cc65 joystick driver may need updates as well; it assumes 2 joysticks where there can now be up to 4 SNES controllers.
  • Thanks 1
Share this post
Link to post
  • 0
The existing routine should work so long as the locations it reads values from have not changed. The SNES pad will work in NES mode - A, X, L, and R are inop in this mode, and B->NES A, Y->NES B. Start, Select, and D-Pad are identical.
  • Like 1
Share this post
Link to post
  • 0
Almost certainly, as the controllers were moved from VIA#2 to VIA#1. I haven't looked into this at all as I don't have a game controller to test this with. Keyboard emulation works in the emu, though, I don't know how that's done.
Share this post
Link to post
  • 0
I'm not testing with an actual controller either, just with the keyboard emulation and am seeing weird results, so I'll need to chase further.  It may or may not be related to the above issue I mentioned.
Share this post
Link to post
  • 0
Don't bother with a PR.  We won't update until R39 is released officially.
  • Like 1
  • Thanks 1
Share this post
Link to post
  • 0
On 4/6/2021 at 9:32 AM, ChrisL said:
It looks like there's a known issue with joysticks (https://github.com/commanderx16/x16-rom/issues/194), but I think there will also need to be updates to the joystick constants in cx16.h, as they are for NES rather than SNES.  The cc65 joystick driver may need updates as well; it assumes 2 joysticks where there can now be up to 4 SNES controllers.
Those constants are for cc65's joystick driver.  The Commander version uses the KERNAL function joystick_get.  The driver knows the difference between NES and SNES.  The "standard" driver always uses buttons A and B as fire buttons 1 and 2.
If someone feels that other buttons are more convenient as the fire buttons, then more joystick drivers can be added to the library.
Share this post
Link to post
Join the conversation
Guest
Answer this question...
  Only 75 emoji are allowed.
  • Create New...
Important Information
