I am working on a little project in screen mode 0.
I can set the screen mode in basic. I can also set it in c.
But when I set it in c, I get incorrect scrolling. It seems the scroll routing still thinks the screen is 60 characters high. I can't find it in the manual. (I probably put my blind glasses on :))
Scrolling is done like this. Print lots of character until the lower end of screen is reached, will trigger scrolling. It's rough, but it works.
What am I missing? I tried checking vera registers after doing a "manual" screen command, and the only thing I came to is the patter 0110 in the mapwidth, map heigh sections of the L1_CONFIG register. (hence *vl1_cfg = 96; )
Question
CursorKeys
Hi!
The screen setting is basically like this:
*vera_video = 0x20 | 0x10 | *vera_video;
*vera_hscale = 0x40;
*vera_vscale = 0x40;
*vl1_cfg = 96;
*vl1_map = 0x00;
Thanks
CC
Link to comment
Share on other sites
2 answers to this question
Recommended Posts
Join the conversation
