Jump to content
How to access Files and Directories on the SD card with CC65
 Share
Recommended Posts
The commands for file and directory access are in <cbm.h>.  Here are the example functions I used to try them out.
unsigned char readFile(const char *filename)
    char s[200];
    unsigned char lfn = 1;
    unsigned char dev = 8;
    unsigned char sec_addr = 0;
    unsigned char res = cbm_open(lfn, dev, sec_addr, filename);
    if (res == 0)
        cbm_read(lfn, s, 200);
        cbm_close(lfn);
        printf("data: %s\r\n", s);
    return res;
void readFile2(const char *filename)
    char buf[200];
    FILE *fp = fopen( filename, "r" );
    if (fp)
        fgets(buf, 100, fp);
        fclose(fp);
        cprintf("data: %s\r\n", buf);
unsigned char readDir(const char* path)
    struct cbm_dirent dir;
    unsigned char res = cbm_opendir(1, 8, path);
    printf("dir: [%s]\n", path);
    if (res == 0)
        printf("listing for %s:\n", path);
        cbm_readdir(1, &dir); // disk header
        printf("file              blocks     type  access\n"
               "----              ------     ----  ------\n");
        while (cbm_readdir(1, &dir) == 0)
            switch(dir.type)
                case 2:  textcolor(8); break;
                case 17: textcolor(7); break;
            cprintf("%-18s %5u     %3s   %u\r\n",
                dir.name,
                dir.size,
                dir.type == 2? "dir" : dir.type == 17? "prg" : "???",
                dir.access);
	            textcolor(1);
        cbm_closedir(1);
    return res;
Edited by rje
Link to comment
Share on other sites
Tom adds an additional note about changing directories:
To change directories on the CMDR-DOS device, you need to open a file with device 8 and secondary address 15. Set the filename to the DOS command to change directory:
"CD:directoryname"
After that, you can close the channel. (In fact, you should close it. If you don't, you will eventually get an error as the system runs out of free I/O channels.)
  • Like 1
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
