Jump to content
Building your own "Neanderthal X16"
 Share
Recommended Posts
Seeing the technical depth of discussions from several engineers here has made me wonder.
Many of you have 65C02s handy.  Some have Ben Eater's kits.  I watched his videos.  And I've recently looked at SRAMs on Mouser.
And you guys know all about this stuff.  I mean some of you actually understand ALL of what's going on.
Just by using Ben's videos, I could probably get a 65C02 connected to the KERNAL (on EEPROM) and a static RAM.  Assume a non-banked memory model.
I mean, the design is COTS on purpose.  If I can get that far, some of you could get quite a bit farther.  VERA notwithstanding.
Am I right?
Edited by rje
Link to comment
Share on other sites
I may not have a VERA, but I do have some YM2151 chips 😁
Seriously, though, I suspect this is a great big honkin' example of ye olde "Dunning-Kreuger" in action for most of us. Sure, we know how clock cycles work, how busses work, how to hook up all this stuff and how it talks to each other, but the complexity goes much deeper than an Eater student (myself included) must realize.
The 8MHz barrier has proven quite the hurdle for the team. I know Kevin has quite a bit of experience making real circuits / boards / etc. If the likes of him and M. Steil have trouble getting the real HW to make liftoff, then clearly someone like me who understands quite a bit of the theory of what's going on would face many unforeseen obstacles and challenges. I'm sure an O-scope is pretty much mandatory to live in that realm, and I have none. I think Adrian's video where he talks about his assistance in troubleshooting proto 2 is an eye-opener to just how sensitive these timing issues really are. And then there's capacitance issues with the traces, etc - none of which we know much about from breadboarding videos except the basic introduction to the topic when Ben demonstrated how harmonics of the clock signal will be attenuated as the clock speed increases.
  • Like 1
Link to comment
[...snipped Adrian's Digital Basement mention re timing...]
Granted.  I mean, I get that.  The X16's problems are Adrian Difficult.
So, what about backing it to Amateur Difficult?  Can I build a Neanderthal X16?
I'll write before I think: how about the Ben Eater design (or for that matter the W65C02SXB) with the MIST KERNAL?
The short answer is: no.  The KERNAL really depends on hardware being a certain way.  I suspect it won't work at all with bits missing.  The whole POINT of much of MIST's KERNAL is that it makes use of all the special hardware in the X16, that is, VERA, and the banks.
The longer answer is: this is what 8BG went through already.  A KERNAL would have to be written, and almost none of it could be ported from the existing KERNAL.
Edited by rje
Link to comment
Even Ben himself struggled with (or pretends to in order to make vids more dramatic w tasty teaching moments) timing diagrams and issues.
Quadrupling the clock speed doesn’t lend to improved tolerance.  Before architectures drastically changed in the 90s, wait states were necessary and while I’m no expert, it’s clear that some of this isn’t as simple as it looks on TV.
Whomever is left should throw in the towel and just release a 2mhz version so people can get their grubby hands on something.
OR slow down to snails pace during SD card IO and revert to a non PS/2 kbd.  Wouldn’t be the first.  Or off-board it to a C=key.  I think the Vera working right (sounds like they already have this?) is the important part.
In summary, take my f’ing money already,‘good enough is good enough’.
We already lost that cry baby guy that left a month or two ago after making a stink in the retro forum, and now Christian has jumped.
Link to comment
I believe this is a four layer board. The Vcc plane and Ground plane in the middle do a lot to mitigate those capacitance issues. Not all of course.
Link to comment
  • Administrators
Yes, I also noted that to myself. And I remeber Ben Eater said in one of the videos something like, that his projects work well on breadboards because of low speeds (like 1 MHz). So I think what @rje is proposing might be possibe at slow speeds only.
Link to comment
  • Super Administrators
Am I right?
I've been thinking of buying the WDC W65C02SXB  development board and adding some RAM to that. That makes more sense to me than building a system from scratch. It would require a text terminal for display, but I actually have one of those in a project box right now.
I believe there's also a RC2014 6502 board out there. In fact, here's an example: http://forum.6502.org/viewtopic.php?f=4&t=4571
That has the advantage of being a proven design with support already out there in the wild.
Edited by TomXP411
Link to comment
I've been thinking about borrowing pieces from MiSTer cores to build a custom machine based on 65816 with a full address space. I don't think in a physical circuit mindset (yet), but think it would be cool to instantiate something that has a certain cadre of HDL based chips. It could then be fun to extend the 65816 using the "reserved for future use" opcode.
Link to comment
That sounds interesting. In my 65816 emulator, I used the WDM opcode for things that a physical machine would never do: throttling back the emulator, to let the host CPU slow down, for example. That would also be a good place to stick MUL and DIV instructions... maybe with signed and unsigned variants.
Link to comment
So, what about backing it to Amateur Difficult?  Can I build a Neanderthal X16? ...
As in, 6.25 MHz? I/O page at $C000-$C0FF overlaying the bottom page of the 16K ROM window, a single 512K RAM and a 64K RAM with the bottom 32K of Low RAM locked at $0000-$7FFFF, an 8K window at $8000-$9FFF and another at $A000-$BFFF, the high window six bits of banks over the full range of 512K, the low window two bits of four 8K banks for the other 32K of Low RAM?
Edited by BruceMcF
Link to comment
My recommendation would be - don't make a Neanderthal X16. Make a Neanderthal something else that uses similar parts. There are a few things about the X16 that make it tougher than it first appears. There's a reason I and the two others I know of who have made X16-like prototypes have all used SPLDs for one or both of address decoding and memory banking. Getting the X16 KERNAL up on a non-X16 device is probably a massively more complex task than you may think. Without VERA, you will never have an X16 anyway and you will still need something to provide you with video and storage.
Link to comment
Wavicle, you're right, what I was thinking of isn't really an X16.  It's just a "Commander" of some kind.
And, you're also right about the KERNAL.  It might well have to be written from scratch, and that sounds just painful.
Link to comment
6 hours ago, BruceMcF said:
As in,
  1. 6.25 MHz?
  2. I/O page at $C000-$C0FF overlaying the bottom page
  3. of the 16K ROM window,
  4. a single 512K RAM
  5. and a 64K RAM
  6. with the bottom 32K of Low RAM locked at $0000-$7FFFF,
  7. an 8K window at $8000-$9FFF
  8. and another at $A000-$BFFF,
  9. the high window six bits of banks over the full range of 512K,
  10. the low window two bits of four 8K banks for the other 32K of Low RAM?
Ah, so you're leading the witness.  Yes, I'll bite -- it sounds in the spirit of X16, sans VERA.  What is it?  What's the CPU?  (The Gigatron runs at 6.25 MHz....)
Link to comment
If it's an amateur project, then a lot of people would start with the C64 KERNAL and modify it from there. In part, because the specific project would not be a lot of people.
Link to comment
Either the 65C02 or the 65816 running like a 65802. It's just the Y16 ... the basic X16 approach, but a set of slightly different design decisions that have been proposed along the way.
And plus different simplifications ... exactly 512K extended memory, no mouse, only a control pad and PS/2 keyboard, etc.
I reckon it's just a thought experiment, but since Vera with all of it's nifty features exists, so people who need a bitmap can go there to get one, I'd look into porting the original Gameduino to a new FPGA family, shift it to a more standard 640x480 VGA display mode, strip out the sound generators, and give it an SPI (master) port that the J1 coprocessor can run. With a system clock synchronous with the Gameduino external clock (why 6.25MHz = 25MHz/4), designing the 6502 bus interface so that there is no contention with the J1 should be a lot simpler.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
