Jump to content
  • 1
vera: character sets
JohnGill
 Share
Question
Hi all,
I started developing a hex-based strategy/roleplay game last year but sadly it's been shelved for ages. That was back on r34 of the emulator. I know it's changed loads since then so I've been ploughing through v0.9 of the vera guide to get my code up to date on r37, and I can't find any reference to the character sets.
It used to be the case that the character set pixel data was copied into vram starting at $1F000 and so I could make custom characters by poking that area. Is this still the case?
thanks
John Gill
Link to comment
Share on other sites
5 answers to this question
Recommended Posts
  • 0
Aww, Matt beat me to it. I'm too verbose.
Consider the following BASIC program which dumps the VERA's layer-related registers:
10 PRINT "L0 CONFIG:    "PEEK($9F2D)
20 PRINT "L0 MAPBASE:   "PEEK($9F2E)"
30 PRINT "L0 TILEBASE:  "PEEK($9F2F)"
40 PRINT "L0 HSCROLL L: "PEEK($9F30)
50 PRINT "L0 HSCROLL H: "PEEK($9F31)
60 PRINT "L0 VSCROLL L: "PEEK($9F32)
70 PRINT "L0 VSCROLL H: "PEEK($9F33)
80 PRINT "L1 CONFIG:    "PEEK($9F34)
90 PRINT "L1 MAPBASE:   "PEEK($9F35)"
100 PRINT "L1 TILEBASE:  "PEEK($9F36)"
110 PRINT "L1 HSCROLL L: "PEEK($9F37)
120 PRINT "L1 HSCROLL H: "PEEK($9F38)
130 PRINT "L1 VSCROLL L: "PEEK($9F39)
140 PRINT "L1 VSCROLL H: "PEEK($9F3A)
Run that, and you'll get the following output on r37:
L0 CONFIG: 0
L0 MAPBASE: 0
L0 TILEBASE: 0
L0 HSCROLL L: 0
L0 HSCROLL H: 0
L0 VSCROLL L: 0
L0 VSCROLL H: 0
L1 CONFIG: 96
L1 MAPBASE: 0
L1 TILEBASE: 124
L1 HSCROLL L: 0
L1 HSCROLL H: 0
L1 VSCROLL L: 0
L1 VSCROLL H: 0
Layer 1 is the only layer configured at boot, as you can see.
L1 CONFIG is 96, or $60, which breaks down as setting Map Height to %01, Map Width to %10, T256C to 0, Bitmap Mode to 0, and Color Depth to 0. This is a 128x64 tilemap at 1bpp, with 16-color background and 16-color foreground for each tile.
L1 MAPBASE is 0, so the tilemap data starts at VRAM address $00000.
L1 TILEBASE is 124, or $7C, which breaks down to a Tile Base Address of %011111 or $1F, Tile Height of 0, and Tile Width of 0. The Tile Base Address field only represents bits 11-16 (bits 0-10 are not represented at all, meaning the value has to be aligned to a 2048-byte increment). Multiply that out and you get the VRAM start address of $0F800. Per the other layer settings from this register and L1 Config, each tile is 8x8x1bpp.
  • Like 1
Link to comment
  • 0
That's all really helpful, thanks Stephen, getting to grips with where everything is in the new vera / r37 layout
Link to comment
Join the conversation
Guest
Answer this question...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
