Kernal SAVE is always failing for me, LOAD works fine, or at least in the loading code into different banks does.
I'm using emu r38. Obviously missing something obvious. I followed Matt's Kernal video. The Error code is 04 (FILE_NOT_FOUND), which is a little odd on a SAVE
Here's the snippet of my code, pretty much hardcoded values to test.
lda #1
ldx #SD_DEVICE
ldy #0 ; I've tried #1 as well
jsr SETLFS
lda #11
ldx #<filename
ldy #>filename
jsr SETNAM
lda #$A0 ; data segment starts at $08A0
sta TEMP ; stores start address (TEMP is $3A in zp)
lda #$08
sta TEMP+1
Question
Fippy
Hey commander experts,
lda #1
ldx #SD_DEVICE
jsr SETLFS
lda #11
ldx #<filename
ldy #>filename
jsr SETNAM
lda #$08
sta TEMP+1
lda #TEMP ; start addr
ldx #$FF
ldy #$09
jsr SAVE
bcs @error
filename: .byte "savgame.bin"
Link to comment
Share on other sites
5 answers to this question
Recommended Posts
Join the conversation
