Dacobi Posted January 8 Share Posted January 8 Hi I have a core loop where I wait for VSYNC and then update sound and screen. The sound is 8bit mono PCM SEI(); VSYNC(); ii = 0; while(ii < 256){ if((VERA.audio.control & 0x80)){break;} ii++; if(audio_2nd){ adder = p[l] + p2[l]; VERA.audio.data = adder; } else { VERA.audio.data = p1[l];; } l++; if(l > 4095) {l=0; } } When just playing the one sample everything runs fine. But when adding two samples the game/framerate slows down a lot. How can this be when just adding two char values? The screen part of my core loop is scrolling two layers of tiles and one sprite. Quote Link to comment Share on other sites More sharing options...
0 Greg King Posted January 10 Share Posted January 10 Your code waits for VSYNC, then does its work. It finishes just in time to catch the next VSYNC. If you add a little bit of code, then it can't finish in time -- it just misses the next VSYNC. Maybe, your code must wait for the second next VSYNC! It does nothing for almost an entire frame! Naturally, its frame rate suffers a huge hit. (Try not waiting for VSYNC. See what that does to the rate.) 1 Quote Link to comment Share on other sites More sharing options...
0 Super Administrators TomXP411 Posted January 8 Super Administrators Share Posted January 8 On 1/8/2022 at 1:10 AM, Dacobi said: Hi I have a core loop where I wait for VSYNC and then update sound and screen. The sound is 8bit mono PCM SEI(); VSYNC(); ii = 0; while(ii < 256){ if((VERA.audio.control & 0x80)){break;} ii++; if(audio_2nd){ adder = p[l] + p2[l]; VERA.audio.data = adder; } else { VERA.audio.data = p1[l];; } l++; if(l > 4095) {l=0; } } When just playing the one sample everything runs fine. But when adding two samples the game/framerate slows down a lot. How can this be when just adding two char values? The screen part of my core loop is scrolling two layers of tiles and one sprite. You might look at the generated assembly code to see if the compiler is doing something stupid. Which compiler are you using? Also, have you tried removing the "adder" variable and just doing this? VERA.audio.data = p[l] + p2[l]; I suspect there may be something funny happening in the background. The compiler might be creating and destroying adder unnecessarily, or it might be creating it as a 16-bit number or something else. Not having the declaration for "adder", it's hard to know. Quote Link to comment Share on other sites More sharing options...
0 Dacobi Posted January 8 Author Share Posted January 8 On 1/8/2022 at 10:18 AM, TomXP411 said: VERA.audio.data = p[l] + p2[l]; This has the same result. Adder was defined as a char. I think this is most of the audio loop, but don't understand it. jsr _VSYNC ldx #$00 lda #$00 ldy #$61 jsr staxysp jmp L0798 L077F: ldx #$00 lda $9F3B ldx #$00 and #$80 stx tmp1 ora tmp1 jeq L0784 jmp L0780 L0784: ldy #$62 jsr ldaxysp sta regsave stx regsave+1 ina bne L0789 inx L0789: ldy #$61 jsr staxysp lda regsave ldx regsave+1 ldy #$0A lda (sp),y dey ora (sp),y jeq L078A ldy #$05 jsr ldaxysp jsr pushax ldy #$6C jsr ldaxysp jsr tosaddax ldy #$00 jsr ldauidx jsr pushax ldy #$05 jsr ldaxysp jsr pushax ldy #$6E jsr ldaxysp jsr tosaddax ldy #$00 jsr ldauidx jsr tosaddax ldx #$00 sta $9F3D ;write audio jmp L0791 L078A: ldy #$03 jsr ldaxysp jsr pushax ldy #$6C jsr ldaxysp jsr tosaddax ldy #$00 jsr ldauidx sta $9F3D ;write audio L0791: ldy #$6A jsr ldaxysp sta regsave stx regsave+1 ina bne L0797 inx L0797: ldy #$69 jsr staxysp lda regsave ldx regsave+1 ldy #$6A jsr ldaxysp cmp #$00 txa sbc #$10 bvs L079A eor #$80 L079A: asl a lda #$00 ldx #$00 rol a jeq L0798 ldx #$00 lda #$00 ldy #$69 jsr staxysp L0798: ldy #$62 jsr ldaxysp cmp #$00 txa sbc #$01 bvc L0783 eor #$80 L0783: asl a lda #$00 ldx #$00 rol a jne L077F L0780: ldx #$00 lda #$00 ldy #$5B jsr staxysp ldx #$00 lda #$00 ldy #$59 jsr staxysp ldy #$2F jsr ldaxysp ldy #$20 jsr staxysp ldy #$1E jsr ldaxysp sta regsave stx regsave+1 ina bne L07A4 inx L07A4: ldy #$1D jsr staxysp lda regsave ldx regsave+1 lda #$00 jsr _joy_read Quote Link to comment Share on other sites More sharing options...
0 Dacobi Posted January 8 Author Share Posted January 8 (edited) I just added -O to my build script and that seems to have fixed the problem. (edit) but then just adding audio_2nd_i++; where audio_2nd_i is an int and the problem is back. Edited January 8 by Dacobi Quote Link to comment Share on other sites More sharing options...
0 Dacobi Posted January 8 Author Share Posted January 8 Adding the line int i++ to the audio loop is enough to kill the framerate. Looking at the assembler code the only difference is this snippet: ldy #$08 jsr ldaxysp ina bne L0796 inx L0796: ldy #$07 jsr staxysp ldy #$6A jsr ldaxysp As far as I can tell it just gets the int variable from stack, increases it and stores it again? Quote Link to comment Share on other sites More sharing options...
0 Super Administrators TomXP411 Posted January 9 Super Administrators Share Posted January 9 It depends on what's going on at ldaxysp and staxysp. If that's dealing with the stack, it's an expensive operation. (The most expensive operations on the CPU are stack operations, since they affect multiple memory locations at the same time.) Declaring your counters as Zero Page variables can help, as well. Which compiler are you using? 1 Quote Link to comment Share on other sites More sharing options...
0 Dacobi Posted January 9 Author Share Posted January 9 On 1/9/2022 at 10:14 AM, TomXP411 said: Declaring your counters as Zero Page variables can help, as well. Which compiler are you using? I'm using cc65. Can you declare a variable as zero page in C? Quote Link to comment Share on other sites More sharing options...
0 BruceMcF Posted January 9 Share Posted January 9 On 1/8/2022 at 12:19 PM, Dacobi said: Adding the line int i++ to the audio loop is enough to kill the framerate. Looking at the assembler code the only difference is this snippet: ldy #$08 jsr ldaxysp ina bne L0796 inx L0796: ldy #$07 jsr staxysp ldy #$6A jsr ldaxysp As far as I can tell it just gets the int variable from stack, increases it and stores it again? Yes, this is the expensiveness of a general stack frame stack in the 6502 family. If it was a 256 deep integer stack implemented as a split byte pushdown X-stack, and i++ is item #4 (zero base) on the stack, it's just: LDX TOS INC STLO+4,X BNE + INC STHI+4,X + ... 1 Quote Link to comment Share on other sites More sharing options...
0 Dacobi Posted January 10 Author Share Posted January 10 On 1/10/2022 at 12:00 PM, Greg King said: Maybe, your code must wait for the second next VSYNC! It does nothing for almost an entire frame! Naturally, its frame rate suffers a huge hit. Yes, sorry, I already changed that a few days ago. But at the time it didn't change anything. I would like to setup a custom IRQ handler but haven't looked into doing that in C. If I disable VSYNC altogether the framerate increases a lot but then the screen is torn. Now my loop is: while(notdone){ //process audio //process input SEI() VSYNC() //update screen CLI() } My Audio loop is: VERA.audio.rate = 0; if(2nd_audio){ while(!(VERA.audio.control & 0x80)){ //while(ii<256){ VERA.audio.data = p[l] + p2[l]; //ii++; l++; if(l > 4095) {l=0;} } } else { while(!(VERA.audio.control & 0x80)){ //while(ii<256){ VERA.audio.data = p[l]; //ii++; l++; if(l > 4095) {l=0;} } } VERA.audio.rate = 64; If I uncomment ii++ there's still some slowdown. Quote Link to comment Share on other sites More sharing options...
0 ZeroByte Posted January 10 Share Posted January 10 If you're dealing in PCM, you're probably going to need to make that part of the code using assembly. I recently implemented a non-mixing PCM streaming routine in my zsound library (that I'm planning to share soon with the community). Just a single stream that does nothing but write into the FIFO takes quite a bit of CPU if you're not careful. For instance, my initial implementation took over 40k clock cycles (about 33% CPU) just to move the data into the FIFO for a 22K/16bit/stereo sound. After a few re-works, I got it shaved down to ~16k CPU cycles for the same stream, but this used several tricks like self modifying code and loop unrolling. If you're mixing 2 streams in C, that could be taking up most of your CPU. Another unfortunate truth right now is that the current Keyboard polling routine in R38 / R39 is VERY slow (due to the nature of PS/2) - just pressing a couple of keys causes the VSYNC IRQ handler to run well into the visible frame ~20% or more of the way) 1 Quote Link to comment Share on other sites More sharing options...
0 Dacobi Posted January 10 Author Share Posted January 10 On 1/10/2022 at 12:00 PM, Greg King said: (Try not waiting for VSYNC. See what that does to the rate.) I just moved the screen update to a custom interrupt handler and that increased the framerate and audio processing quite a lot. 2 Quote Link to comment Share on other sites More sharing options...
0 Greg King Posted January 11 Share Posted January 11 Some cc65 tricks that will shorten pieces of your code: Change l++; if(l > 4095) {l=0;} to l = (l + 1) & 4095; Change while(!(VERA.audio.control & 0x80)){ //while(ii<256){ to while ((signed char)VERA.audio.control >= 0) { //while(ii<256){ 1 Quote Link to comment Share on other sites More sharing options...
Question
Dacobi
Hi
SEI();
VSYNC();
ii = 0;
while(ii < 256){
ii++;
if(audio_2nd){
} else {
l++;
Link to comment
12 answers to this question
Recommended Posts
Join the conversation
