I'm working away furiously at writing a routine in assembly that will scroll text within a window on screen for my hexes adventure game, loading text from a memory bank and adding it at the bottom line by line. This is really stretching my assembly skills but I'm enjoying the challenge. I've got my head round using both vera's data0 and data1 to read and write the screen to shuffle up the whole window a line at a time, but I've come across a blip that I can't get my head round, and I'm wondering if someone can please point me in the right direction:
I'm copying a string of characters from somewhere in the ram bank space ($A000 upwards), which is referenced by two ZP vars that I've assigned to variables thus:
startHi=$14
startLo=$15
I've written the maths routines to calculate the start position of the required string, which sets startHi to say, $A1, and startLo to say, $34. The maths routines I've tested and know are working, they give the correct values in startHi and startLo for the base position of the text within the ram bank.
My problem seems to be actually copying those bytes to the screen. I'm feeling exceptionally clever for working out how to use the y register in indirect indexed addressing mode to step through the memory thus:
loop:
lda (startHi),y
..... do stuff
But it ain't working (yet ).
If I've understood things correctly, this is supposed to look at the byte at memory address startHi ($14 for me) *and* the byte at memory address startHi+1 ($15, startLo) and use that as a two-byte base address, and then add on the value of y. Is that right?
When I run the routine, it just writes a ton of "@" to the screen. I've set the break point at the start of the loop with the debugger monitor thing (very useful), and it steps through y from $00 > $FF fine, and sure enough, its just loading zeros into the accumulator at the lda (startHi), y line every time. I can see the ZP vars in the debugger, and $14 and $15 are indeed pointing to $A1 and $34 (or whatever), but I don't understand the debugger well enough to work out if I can look at the actual $A134 while I'm stepping through the assembly.
When I print chr$(peek($A134... $A135... $A136 etc)) from basic, then it shows that the characters are indeed present in the ram bank page (see below). So why does my assembly just find zeros?
Question
JohnGill
Hi all,
startHi=$14
startLo=$15
loop:
lda (startHi),y
..... do stuff
Any tips very gratefully received!!!
thanks
Link to comment
Share on other sites
32 answers to this question
Recommended Posts
Join the conversation
