Lodovik 3 Posted July 12, 2020 (edited) Hello, In BASIC, how can I initialize screen $80 mode with colors other than blue on white background? I'd like to draw color shapes on a black background. Thanks Edited July 12, 2020 by Lodovik Quote Share this post Link to post Share on other sites
0 Alfa 5 Posted July 12, 2020 (edited) How about: 10 SCREEN $80 20 REM BORROW COLOR 1 FOR BLACK AS 0 IS TRANSPARENT 30 VPOKE 1, $FA02, 0 40 VPOKE 1, $FA03,0 50 COLOR 6,1 60 CLS Edited July 12, 2020 by Alfa Forgot about the transparent color in mode $80 Quote Share this post Link to post Share on other sites
0 Lodovik 3 Posted July 12, 2020 (edited) Strangely, if I do that, the screen is cleared to the correct color but anything drawn with pset is invisible... and there's no black color, only dark gray (11). Edit: with the above vpokes, I now get a black background screen but still cannot see anything drawn with PSET x,y,color. Edited July 12, 2020 by Lodovik Quote Share this post Link to post Share on other sites
0 SlithyMatt 525 Posted July 12, 2020 Just do a COLOR and whatever index you want to use from the 16-color palette (0-15). You can pass two arguments, and specify the background color. So COLOR 1,6 will get back the familiar white-on-dark-blue look. COLOR 15,11 will get you a trendy light-gray-on-dark-gray "dark mode" look. The only color you can't really use in mode $80 is black, unless you poke it into an index other than zero. 1 Quote Share this post Link to post Share on other sites
0 Lodovik 3 Posted July 12, 2020 OK, I found the problem: I removed the color statement before the CLS and it's now working correctly with a black background, using the VPOKEs. Thanks! Quote Share this post Link to post Share on other sites
0 Michael Steil 66 Posted July 12, 2020 Yeah, SCREEN $80 changed the fg and bg colors. The bg color has to be 0 (transparent, so the graphics below shines through), and the fg color has to be something other than 1 (white, otherwise it's white-on-white), so SCREEN $80 sets the colors to light blue on transparent, ignoring what was set before. Quote Share this post Link to post Share on other sites
0 Greg King 56 Posted July 13, 2020 He asked about graphics, not text. Lodovik, simply paint a black rectangle on the entire screen: RECT0,0,319,199,0 Quote Share this post Link to post Share on other sites
0 Justin Baldock 18 Posted July 13, 2020 Working from Alfa's post this will draw rectangles with a frame and a diagonal line in different colours. 10 SCREEN $80 20 VPOKE 1,$FA02,0 30 VPOKE 1,$FA03,0 40 FOR I=0 TO 20 50 X=RND(1)*320: Y=RND(1)*200: X2=RND(1)*320: Y2=RND(1)*200 60 RECT X,Y,X2,Y2,RND(1)*256 70 FRAME X,Y,X2,Y2,RND(1)*256 80 LINE X,Y,X2,Y2,RDN(1)*256 90 NEXT Quote Share this post Link to post Share on other sites
0 Greg King 56 Posted July 13, 2020 (edited) 10 SCREEN $80 20 RECT 0,0,319,199,0 40 FOR I=1 TO 20 50 X=RND(1)*320: Y=RND(1)*200: X2=RND(1)*320: Y2=RND(1)*200 60 RECT X,Y,X2,Y2,RND(1)*256 70 FRAME X,Y,X2,Y2,RND(1)*256 80 LINE X,Y,X2,Y2,RND(1)*256 90 NEXT 100 LIST Edited September 4, 2020 by Greg King Quote Share this post Link to post Share on other sites
0 geek504 44 Posted September 9, 2020 On 7/12/2020 at 4:17 PM, Michael Steil said: Yeah, SCREEN $80 changed the fg and bg colors. The bg color has to be 0 (transparent, so the graphics below shines through), and the fg color has to be something other than 1 (white, otherwise it's white-on-white), so SCREEN $80 sets the colors to light blue on transparent, ignoring what was set before. This took me a while to figure out properly! Is my understanding below correct? 1. The TEXT layer is on TOP of the GRAPHICS layer. 2. So that TEXT "bg" color has to be set to "0" (transparent) so that the GRAPHICS layer is shown through. 3. SCREEN $80 is permanently defining color 1 (WHITE) as the background color for the GRAPHICS layer. (THIS IS KEY) 4. So in order to change the background color of the GRAPHICS layer, we need to manually alter the color 1 inside VERA's palette memory. 5. Changing the "bg" color of the TEXT layer (using COLOR command) other than "0" will hide the GRAPHICS layer. On 7/12/2020 at 12:31 AM, Alfa said: 10 SCREEN $80 20 REM BORROW COLOR 1 FOR BLACK AS 0 IS TRANSPARENT 30 VPOKE 1, $FA02, 0 40 VPOKE 1, $FA03,0 50 COLOR 6,1 60 CLS Thus LINE 50 in the original code is a mistake... it sets TEXT layer "bg" to the newly created "BLACK" color thus hiding the GRAPHICS layer. The line should read COLOR 6,0 and all is well. It seems a little inflexible to hardcode the GRAPHICS layer background color to "1". Perhaps allowing the user to set the color would be nice... it would avoid those ugly POKEs... Quote Share this post Link to post Share on other sites
0 Ender 60 Posted September 9, 2020 (edited) 42 minutes ago, geek504 said: This took me a while to figure out properly! Is my understanding below correct? 1. The TEXT layer is on TOP of the GRAPHICS layer. 2. So that TEXT "bg" color has to be set to "0" (transparent) so that the GRAPHICS layer is shown through. 3. SCREEN $80 is permanently defining color 1 (WHITE) as the background color for the GRAPHICS layer. (THIS IS KEY) 4. So in order to change the background color of the GRAPHICS layer, we need to manually alter the color 1 inside VERA's palette memory. 5. Changing the "bg" color of the TEXT layer (using COLOR command) other than "0" will hide the GRAPHICS layer. Thus LINE 50 in the original code is a mistake... it sets TEXT layer "bg" to the newly created "BLACK" color thus hiding the GRAPHICS layer. The line should read COLOR 6,0 and all is well. It seems a little inflexible to hardcode the GRAPHICS layer background color to "1". Perhaps allowing the user to set the color would be nice... it would avoid those ugly POKEs... Yes, pretty much. Another thing you could do is fill $10000-$1F9FF with something other than 1 in a for loop or something, but that would be really slow. Edit: Actually Greg King already suggested it, but making a rect that fills the screen is the fastest and easiest way. Also.... is there a way to remove a quote once you've hit the quote button? I can't seem to get rid of it. Quote Edited September 9, 2020 by Ender Quote Share this post Link to post Share on other sites
0 geek504 44 Posted September 9, 2020 1 hour ago, Ender said: Yes, pretty much. Another thing you could do is fill $10000-$1F9FF with something other than 1 in a for loop or something, but that would be really slow. That is something I am wondering too... which way is fastest to reset the GRAPHICS layer to black: 1. SCREEN $80 after setting palette color #1 to black; 2. RECT 0,0,319,199,16 <== can't use color #0 (transparent) so use the next available black; 3. Machine code to fill the screen memory with color #16. Quote Share this post Link to post Share on other sites
0 Ender 60 Posted September 9, 2020 5 minutes ago, geek504 said: That is something I am wondering too... which way is fastest to reset the GRAPHICS layer to black: 1. SCREEN $80 after setting palette color #1 to black; 2. RECT 0,0,319,199,16 <== can't use color #0 (transparent) so use the next available black; 3. Machine code to fill the screen memory with color #16. I think technically 1 would be the fastest since it's just changing one value in memory and the VERA should pick it up for the next frame. However, 2 and 3 are also very fast. They're probably nearly the same speed, since RECT essentially does 3, but it has the added overhead of parsing the BASIC command (which probably equates to just a few milliseconds). Quote Share this post Link to post Share on other sites
Hello,
Thanks
Edited by LodovikShare this post
Link to post
