SplitSpine 1 Posted August 4, 2020 As a new programmer on very limited hardware, how do you make sprites and background appear from outside the monitors border? It seems very easy for the RIGHT and BOTTOM sides, since you just use higher X & Y values then the screen mode use. But you can't use negative values on sprites.... So what's the trick I'm missing? Quote Share this post Link to post Share on other sites
0 StephenHorn 287 Posted August 4, 2020 The trick is that even though the X and Y values are technically "unsigned" (i.e. non-negative), you can still get the effect of negative numbers by going ahead and subtracting from 0. The value will "underflow", but you can write the bits to the VERA anyways and it will treat it like a negative number. Another way to look at it is that you've moved the sprite so far off the right side of the screen, that the VERA eventually wraps part of the sprite around to the left edge. 1 Quote Share this post Link to post Share on other sites
0 SplitSpine 1 Posted August 5, 2020 16 hours ago, StephenHorn said: The trick is that even though the X and Y values are technically "unsigned" (i.e. non-negative), you can still get the effect of negative numbers by going ahead and subtracting from 0. The value will "underflow", but you can write the bits to the VERA anyways and it will treat it like a negative number. Another way to look at it is that you've moved the sprite so far off the right side of the screen, that the VERA eventually wraps part of the sprite around to the left edge. Thanks for the explanation, it was really helpful. I used the basic sprite example to test it out. Seems that X coordinate starts over at $400 or 1024 (so the same as $000 or 0). Still not sure how to make an "underflow" even in assembler, well I might be able to do it to 1 byte, but the X coordinate consist of 2 bytes. Quote 10 REM 'ADDRESS 12:5 20 VPOKE $1,$FC00,0 30 REM 'ADDRESS 16:13 (STARTING AT $10000) AND 8 BPP MODE 40 VPOKE $1,$FC01,$88 50 REM 'X COORDINATE 7:0 60 VPOKE $1,$FC02,250 70 REM 'X COORDINATE 9:8 80 VPOKE $1,$FC03,3 90 REM 'Y COORDINATE 7:0 100 VPOKE $1,$FC04,55 110 REM 'Y COORDINATE 9:8 120 VPOKE $1,$FC05,0 130 REM 'Z-DEPTH: IN FRONT OF LAYER 1 140 VPOKE $1,$FC06,$0C 150 REM '16 PIXELS FOR WIDTH AND HEIGHT 160 VPOKE $1,$FC07,$50 170 REM 'COPY SMILEY SPRITE DATA TO VIDEO RAM 180 GOTO 500 180 FOR I=0 TO 255 190 READ A 200 VPOKE 1,I,A 210 NEXT I 220 REM 'ENABLE SPRITES 230 POKE $9F29,PEEK($9F29)OR$40 240 END 500 DATA 00,00,00,00,00,16,16,16,16,16,16,00,00,00,00,00 510 DATA 00,00,00,16,16,07,07,07,07,07,07,16,16,00,00,00 520 DATA 00,00,16,07,07,07,07,07,07,07,07,07,07,16,00,00 530 DATA 00,16,07,07,07,07,07,07,07,07,07,07,07,07,16,00 540 DATA 00,16,07,07,07,16,07,07,07,07,16,07,07,07,16,00 550 DATA 16,07,07,07,07,16,07,07,07,07,16,07,07,07,07,16 560 DATA 16,07,07,07,07,16,07,07,07,07,16,07,07,07,07,16 570 DATA 16,07,07,07,07,07,07,07,07,07,07,07,07,07,07,16 580 DATA 16,07,07,07,07,07,07,07,07,07,07,07,07,07,07,16 590 DATA 16,07,07,07,07,07,07,07,07,07,07,07,07,07,07,16 600 DATA 16,07,07,16,07,07,07,07,07,07,07,07,16,07,07,16 610 DATA 00,16,07,07,16,07,07,07,07,07,07,16,07,07,16,00 620 DATA 00,16,07,07,07,16,16,16,16,16,16,07,07,07,16,00 630 DATA 00,00,16,07,07,07,07,07,07,07,07,07,07,16,00,00 640 DATA 00,00,00,16,16,07,07,07,07,07,07,16,16,00,00,00 650 DATA 00,00,00,00,00,16,16,16,16,16,16,00,00,00,00,00 670 GOTO 190 Quote Share this post Link to post Share on other sites
0 StephenHorn 287 Posted August 5, 2020 (edited) "Underflowing" is just what happens when you try to subtract a larger unsigned number from a smaller unsigned number. So, okay, let's suppose you have some 8-bit value, such as %00001011 (which is 11). If I subtract %00001100 (12) from it, I get %11111111 (255), because the math "underflowed". Instead of just stopping at zero, the computer kept going. It's exactly the same thing as when you start with %11111111 (255) and add 1, the computer "overflows" to %00000000. When crossing 0 with a subtraction, it's called an "underflow". And in fact, whenever you see a binary number with the highest bit set, you can also think of it as the negative version of the number you get when you invert all the bits and add 1. So %11111111 (255) can be seen as -1, or %00000000 (0) plus 1. The reason the VERA "starts over at $400" is because the sprite position is only 10 bits wide (see also: VERA reference). $400 is %0100 00000000, in which the lower 10 bits are all zero. So the VERA sees that as %00 00000000. The assembly instructions you'll work with will generally work in 8-bit units instead of 10-bit units, but if you have some pair of bytes %00000000 and %00000000, and subtract %00000001 and %00000000, you'll get %11111111 and %11111111. You can just chop off the top 6 bits from the second byte when you write them to the VERA, because the VERA will only see it as %11 11111111 anyways. Edits: Trying to figure out the best phrasing to teach the concept... Edited August 5, 2020 by StephenHorn Quote Share this post Link to post Share on other sites
Share this post
Link to post
