So I started to make my Scary Forest program more Roguelike... and the first thing I did was implement a "fog of war" on the map.
It's a great idea: don't draw the map! Saves time! Only draw new bits when you get within, say, 4 moves. And then you can "see" monsters... and they can see you... and start lumbering towards you. I mean this is a win-win, right?
So I'll tell you: it DOES improve the feel of the game... a LOT. It adds some suspense. It adds an exploration element to the game. So there's emergent gameplay that I didn't realize was there. Once I add treasure, it'll be a whole new ball game.
...BUT...
...What I've found is that even drawing a 9 x 9 map from a 2D array, then handling player and monster movement, is too slow. Yeah, even with the Commander X16, it's too slow.
I optimized. I went memory-lazy and use an array of floats instead of ints. I got rid of newline printing and went all cursor controls. Up, down, left, right. It helps. But... it's still slow. It turns out that adding a line of logic here and there really add up fast... and this is just PETSCII!
So I'm fishing for suggestions. I've started asking myself what assembly language I can write to get the most speedup for the least amount of pain. Maybe the map drawing routine: fairly straightforward, no funny checking of data and switching around, so not a big chunk of code. I guess I'd POKE the map into a bank, and the ML would use ZP indirect indexing to find the right data, do a PLOT, and render the PETSCII. Next square. Do it from x-4 to x+4, y-4 to y+4. Maybe?
Or maybe I should use sprites for the player and monsters? They would sit "on top" of the map, so I wouldn't be drawing over it; surely that might help?
Question
...BUT...
Anyone got better ideas?
Link to comment
Share on other sites
21 answers to this question
Recommended Posts
Join the conversation
