desertfish Posted September 18, 2020 Share Posted September 18, 2020 For instance I've uploaded multiple iterations of the program with the same filename and the Try it now no longer works. It used to work fine when there was just the first version. Quote Link to comment Share on other sites More sharing options...
SlithyMatt Posted September 19, 2020 Share Posted September 19, 2020 The old versions are still there even if you "delete" them in the current file space. You can always browse the history to retrieve those old versions, so deleting them when uploading updates is the proper process. Quote Link to comment Share on other sites More sharing options...
Super Administrators Perifractic Posted September 19, 2020 Super Administrators Share Posted September 19, 2020 6 hours ago, desertfish said: For instance I've uploaded multiple iterations of the program with the same filename and the Try it now no longer works. It used to work fine when there was just the first version. @MattGrandis any ideas about this sir? Quote Link to comment Share on other sites More sharing options...
Super Administrators Perifractic Posted September 19, 2020 Super Administrators Share Posted September 19, 2020 ...deleting them when uploading updates is the proper process.I'd respectfully disagree with this. It's good to have all versions available rather than delete them (that's why the feature is there). Let's see if we can figure out why Try It Now is failing. Quote Link to comment Share on other sites More sharing options...
SlithyMatt Posted September 19, 2020 Share Posted September 19, 2020 1 minute ago, Perifractic said: I'd respectfully disagree with this. It's good to have all versions available rather than delete them (that's why the feature is there). That was my point, that the old versions are still there, just not part of the current download version. You can't actually permanently delete anything from Downloads without admin intervention. Quote Link to comment Share on other sites More sharing options...
Super Administrators Perifractic Posted September 19, 2020 Super Administrators Share Posted September 19, 2020 That was my point, that the old versions are still there, just not part of the current download version. You can't actually permanently delete anything from Downloads without admin intervention.Ah when you said "deleting them" was the proper process I read that as you recommended deleting them (by an admin or whoever). Glad we sorted that out [emoji6] 1 Quote Link to comment Share on other sites More sharing options...
Super Administrators Solution Main Administrator Posted September 20, 2020 Super Administrators Solution Share Posted September 20, 2020 On 9/19/2020 at 5:56 AM, Perifractic said: @MattGrandis any ideas about this sir? Working again! The script tried to use all versions at the same time. Whoopsie. 3 Quote Link to comment Share on other sites More sharing options...
Super Administrators Perifractic Posted September 20, 2020 Super Administrators Share Posted September 20, 2020 Haha wow. Well done to it for trying to be ambitious though. Quote Link to comment Share on other sites More sharing options...
desertfish Posted September 20, 2020 Author Share Posted September 20, 2020 you guys are awesome thanks for responding so quickly 1 Quote Link to comment Share on other sites More sharing options...
Recommended Posts
