Jump to content
Basic file loads
Uberlinc
 Share
Recommended Posts
Hi,
This might seem like a silly question, and I've searched many websites (including YouTube etc) to find the answer but I've found no clear, simple answer.
Apologies if this has been asked before.
I have the X16 emulator installed.
I downloaded the "Invaderz" program.
So, according to standard Commodore commands, you type: LOAD"PROGRAMNAME.PRG"
However, it can't seem to find it.
I have my emulator sitting under C:\Program Files.
Where is the best place to place it?
Where is the best place to keep your stash of programs relative to the emulator?
When you type "LOAD", how do you specify relative location of the program file?
I even tried placing a copy of "INVADERZ.PRG" into the emulator directory itself.
Is there a Dummies' Guide explaining this?
Can anyone point me to this?
Thanks.
  • Like 1
Link to comment
Share on other sites
  • 4 months later...
I am using Windows 10 Pro, I have the x16 Emulator in a folder at C:\x16, and I have game files in a folder at C:\x16\games. I have don't have any past experience with a C64 or with the x16 Emulator. I have gotten some games to load into x16, such as Crazy Snakes, but I have not been able to get Chase Vault to load. Could I get a newbie walkthrough on how to get Chase Vault to load in the x16 Emulator? Thanks
Edited by William
Link to comment
If you download the ZIP file from here, or get the release build from GitHub, just make sure that CHASVALT.PRG and all the .BIN files are in the same directory, then launch the emulator from that very directory. To make it run immediately, you can just do that from the command line:
x16emu -prg CHASVALT.PRG -run
But you could just run the emulator without argument, and just load and run it from inside the emulator:
LOAD"CHASVALT.PRG"
RUN
All of this guidance is also available, including a list of all the .BIN files in the repo's README: https://github.com/SlithyMatt/x16-chasevault
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
