Jump to content
  • 0
Loading Data into VRAM (Kick Assembler)
paradoxnj
 Share
Question
After being semi-successful with C, I am trying my hand at assembler again. 🙂  I am running into an issue loading data directly into VRAM.  Using the emulator's debugging feature, I see my load function is using the correct address. and I have the bank hard coded to "2" right now.  I am using Kick Assembler with Visual Studio Code.
My function is as follows:
// Function:  load_vram
// Args:      A = VRAM Low Byte
//            X = VRAM High Byte
//            Y = filename (7:0)
// Brief:     Loads a file into VRAM
load_file_into_vram: {
        clc
        stz ROM_BANK
        sta ZP_PTR_1                    // Store Low Byte
        stx ZP_PTR_1+1                  // Store High Byte
        sty ZP_PTR_2                    // Store file name low byte
        // SETLFS
        lda #1
        ldx #HOST_DEVICE
        ldy #0
        jsr SETLFS
        // SETNAM
        ldy #>filenames
        sty ZP_PTR_2+1
        ldy #0
!:      lda (ZP_PTR_2),y
        beq !+
        iny
        jmp !-
!:      tya                             // Filename size
        ldx ZP_PTR_2                    // Filename (Low Byte)
        ldy #>filenames
        jsr SETNAM
        // LOAD
        lda #2                          // Bank
        ldx ZP_PTR_1
        ldy ZP_PTR_1+1
        clc                             // Clear the carry
        jsr LOAD
        bcs err
        rts
err:    cmp #$05
        beq dev_error
        cmp #$04
        beq file_error
        cmp #$1D
        beq load_error
dev_error:
        lda #<dev_error_msg
        ldx #>dev_error_msg
        ldy #(end_dev_error_msg-dev_error_msg)
        jmp prt
file_error:
        lda #<file_error_msg
        ldx #>file_error_msg
        ldy #(end_file_error_msg-file_error_msg)
        jmp prt
load_error:
        lda #<load_error_msg
        ldx #>load_error_msg
        ldy #(end_load_error_msg-load_error_msg)
        jmp prt
prt:    jsr print_string
        rts
My function call, looks like this:
        lda #>(VRAM_palette & $FFFF)
        ldx #<(VRAM_palette & $FFFF)
        ldy #<pal_fn
        jsr load_file_into_vram
I keep getting a "FILE NOT FOUND" error ($04) and static on the screen.  Any help would be appreciated.
Edited by paradoxnj
Link to comment
Share on other sites
20 answers to this question
Recommended Posts
  • 0
I made some progress today.  I loaded the palette using the "Kick Assembler" way and copied it to VRAM.  Now the palette is red and I also found out that the image is actually being loaded even though it is giving me a "FILE NOT FOUND" error and the carry flag is being set.
The "Kick Assembler" way is as follows:
.var palette = LoadBinary("FF1TS1.PAL"BF_C64FILE)
bmp_palette.fill palette.getSize(), palette.uget(i)
Link to comment
  • 0
Finally got it!!!  I used a macro instead of a function for load_file_into_vram.  I was able to abstract the bank that way and keep it like a function call.  I know that is repetitive code in the end and I will still work to get that correct but for now it works.
.macro loadVRAM(filename, filenameLength, address) {
        lda #filenameLength
        ldx #<filename
        ldy #>filename
        jsr CX16.SETNAM
        lda #1
        ldx #CX16.HOST_DEVICE
        ldy #0
        jsr CX16.SETLFS
        ldx #<(address & $FFFF)
        ldy #>(address & $FFFF)
        lda #((address >> 16) & $F)
        clc
        adc #2
        clc
        jsr CX16.LOAD
bmp_pal:
    .text "FF1TS1-X16.PAL"
bmp_pal_end:
loadVRAM(bmp_pal, bmp_pal_end-bmp_pal, CX16.VRAM_palette)
loadVRAM(bmp_file, bmp_file_end-bmp_file, VRAM_TILES)
This is just a full screen render of a bitmap I had.  I am using it for learning as the tiles are 16x16.  Now to figure out tile mode using this bitmap.
Link to comment
  • 0
Refined the macro a bit more and got rid of the clc and adc instructions.
        lda #filenameLength
        ldx #<filename
        ldy #>filename
        jsr CX16.SETNAM
        lda #1
        ldy #0
        jsr CX16.SETLFS
        lda #(((address >> 16) & $F) + 2)
        clc
        jsr CX16.LOAD
Link to comment
  • 0
Just now, StinkerB06 said:
It's possible to use the carry flag as a 1-bit argument.
But LOAD doesn't use the carry bit as an input argument. It is used as an output, but the state of the flag going in should not have any effect on the result of the call. At least, that's how the legacy LOAD function worked. It could have changed for the X16, but not to my knowledge.
Link to comment
  • 0
I finally got the function working correctly.  I had to use the Zero Page for some of the function arguments, but the function is repeatable now.  The given example shows how I load a palette file into VRAM at the VERA palette location.  Again...this is using Kick Assembler.
; Function:         loadIntoVRAM
; Uses:             A = filenameLength
;                   X = filename msb
;                   Y = filename lsb
;                   ZP_ARG1 = ADDR_LO
;                   ZP_ARG2 = ADDR_MID
;                   ZP_ARG3 = ADDR_HI
; Returns:          A = 0 on success
;                       1 on failure
; Description:      Loads a file into VRAM
loadIntoVRAM: {
    jsr CX16.SETNAM
    lda #1
    ldy #0
    jsr CX16.SETLFS
    lda CX16.ZP_ARG3
    ldx CX16.ZP_ARG1
    ldy CX16.ZP_ARG2
    clc
    jsr CX16.LOAD
    bcs errfile
    lda #0
    rts
errfile:
    lda #1
    rts
Used like this:
        lda #((CX16.VRAM_palette >> 16) & $F) + 2
        sta CX16.ZP_ARG3
        lda #<(CX16.VRAM_palette & $FF00) >> 8
        sta CX16.ZP_ARG2
        lda #>(CX16.VRAM_palette & $FF)
        sta CX16.ZP_ARG1
        ldx #<bmp_pal
        ldy #>bmp_pal
        lda #(bmp_pal_end-bmp_pal)
        jsr loadIntoVRAM
Edited by paradoxnj
Link to comment
  • 0
35 minutes ago, paradoxnj said:
loadIntoVRAM: {
    jsr CX16.SETNAM
    lda #1
    ldy #0
    jsr CX16.SETLFS
    lda CX16.ZP_ARG3
    ldx CX16.ZP_ARG1
    ldy CX16.ZP_ARG2
    clc
    jsr CX16.LOAD
    bcs success
    lda #1
success:
    lda #0
    rts
You should put an rts before the success label. As it is, if you detect a failure, you still lda #0 so the caller of this function will always see it as successful.
Link to comment
  • 0
Yep...thanks.  I put it there after I posted this.  I realized it was missing.  Edited the post to reflect it.  Thanks again.  I also just realized that I have the check backwards.  It should be success if the carry is not set.  🙂
Edited by paradoxnj
  • Like 1
Link to comment
Join the conversation
Guest
Answer this question...
  Only 75 emoji are allowed.
 Share
  • Create New...
Important Information
