JimmyDansbo 66 Posted October 23, 2020 I have been trying to help the KERNAL development by creating the HEX$ and BIN$ BASIC commands/tokens, but I do not understand enough of the KERNAL source to actually figure out how to create a new command/token. Kan anyone point me in the right direction as to what I am missing? See my note on the issue here: https://github.com/commanderx16/x16-rom/issues/49#issuecomment-714964134 Thanks in advance Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 23, 2020 Hey I was wondering about the lack of HEX$ and BIN$ myself as well so this is an iteresting topic to me! I would like to see if I can perhaps help you with this but I have zero experience with building a custom rom though right now. I don't know if that is difficult to set up? Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 23, 2020 (edited) It is not too bad to setup the environment to build a custom rom, if you have a look at https://github.com/commanderx16/x16-rom the README.md tells you how to do it. I have actually managed to create the HEX$ keyword in ROM, now I just need to figure out how to return a string. Aparently I can not return a multi-byte string the same way as CHR$ returns a single-byte string You can follow my progress here: https://github.com/JimmyDansbo/x16-rom Edited October 23, 2020 by JimmyDansbo Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 23, 2020 (edited) first reaction is: look at how left$ is returning a string? (disclaimer: i have no idea at all how to look into the BASIC rom for how it executes certain tokens....) Edited October 23, 2020 by desertfish Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 23, 2020 2 minutes ago, desertfish said: first reaction is: look at how left$ is returning a string? Yeah, I have been looking at CHR$, STR$, LEFT$, RIGHT$ and MID$ I still can not get my head around how a string gets allocated, populated and returned correctly. The way it is done in CHR$ seems fairly simple, but when I try to allocate space for more than 1 byte, I get a type mismatch Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 23, 2020 I'm intrigued I hope to find some time this weekend to spend on this issue! Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 23, 2020 (edited) @JimmyDansbo I made a pull request on GitHub to your repository, with what I think should be a working HEX$ including the ability to accept numbers up to 65535 I think it should use the existing routines from the Monitor, but that gave me a 'symbol undefined' error during building of the rom... I dunno how to access it. Also I am not sure if this is even possible because it is in a different memory bank perhaps??? (I'm a bit unfamiliar with how that works still) So for now I simply copied the byte_to_hex_ascii routine from monitor.s almost verbatim into here Edited October 23, 2020 by desertfish Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 24, 2020 @desertfish That is great, I will look into if it is possible to just jump to the monitor code even though it is in another bank. Thanks Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 24, 2020 6 hours ago, desertfish said: I think it should use the existing routines from the Monitor, but that gave me a 'symbol undefined' error during building of the rom... I dunno how to access it. Also I am not sure if this is even possible because it is in a different memory bank perhaps??? (I'm a bit unfamiliar with how that works still) If you look close to the top of the x16additions.s file https://github.com/JimmyDansbo/x16-rom/blob/1ab984f18aa5068af6be5368a997810fa1a4e666/basic/x16additions.s#L53 You can see how it goes about calling the monitor from BASIC. When the ROM is compiled, the monitor.sym file tells us that the byte_to_hex_ascii function has address $C829 so what we can do is this: Quote jsr bjsrfar .word $C829 .byte BANK_MONITOR I have tested it and it does work, however I think it adds a lot of overhead and if the code in monitor is changed, our $C829 constant needs to be changed. Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 24, 2020 (edited) I have now implemented both HEX$ and BIN$ and there is NO more room in the 16KB BASIC ROM page. I have had to change the functions to only accept a single byte and I have removed any preceding characters ('$' and '%'). Also it was necessary to to actually use the byte_to_hex_ascii function from the MONITOR code to make the functions fit in BASIC ROM. Please have a look and let me know if there is anything that should be changed or improved. Otherwise I will do a pull request against the official branch. Edited October 24, 2020 by JimmyDansbo Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 24, 2020 Hmm, was it because of the ROM size limitation that the 16-bit support had to be dropped? Very unfortunate.... Also I would have expected that using ".import byte_to_hex_ascii " would enable you to use the symbol rather than the absolute address but that doesn't work. I'm not familiar enough with the tool chain to come up with a possible solution for this. Is there someone else that can? I think referring to the absolute address of the function is quite brittle Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 24, 2020 2 minutes ago, desertfish said: Hmm, was it because of the ROM size limitation that the 16-bit support had to be dropped? Yes, I think there might be a single byte available after these functions have been added as they are now. Also, I think that the functions will mostly be used to show output of peeks and vpeeks which are only a single byte anyway ? 3 minutes ago, desertfish said: I think referring to the absolute address of the function is quite brittle I totally agree, but I don't know how to be able to use the name either. I am thinking that ROM maintainer will let us know if I do a pull request Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 24, 2020 I hope so, may be wise to mention this issue in the PR Anyway it's great we got something working Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 24, 2020 Yes indeed. How did you figure out that it was necessary to do pla twice before jmp'ing to strlit ? Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 24, 2020 I looked at the disassembly for several other tokens and kinda played with it, i started by just copying the code from STR$ and went from there I believe. I don't understand basic's execution loop and things I just copied stuff from elsewhere until it worked... 1 Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 25, 2020 Argh, I just tried compiling the new ROM with the PRERELEASE_VERSION set and then it is too large to fit in the 16KB ROM page Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 25, 2020 (edited) I managed to free up some space in the BASIC ROM page. https://github.com/JimmyDansbo/x16-rom/commit/a0470c136811ef56c6f3d5131bc9ffa1d254f9b6 @desertfish do you think we should try and go for handling word values as well as byte values? Edited October 25, 2020 by JimmyDansbo Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 26, 2020 I would like to see support for word values, to mirror the ability of the '$' and '%' prefixes to deal with words. However your argument about the actual real world usage of HEX$ and BIN$ are relevant too. I mostly need the full 16 bits when in an assembly environment, and we have the monitor for that..... Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 26, 2020 Now that space is freed in the BASIC ROM page, I think it will actually be possible have the functions handle word values as well. Do you think it would be sufficient that HEX$ outputs a 4 byte string if the value is larger than 255 otherwise a 2 byte string? Or should it be something that you specify when calling i.e. something like HEX$(42, 1) returns 2A and HEX$(42, 2) returns 002A Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 27, 2020 For me it's perfectly fine if HEX$(255) -> FF and HEX$(65535) -> FFFF Quote Share this post Link to post Share on other sites
Greg King 50 Posted October 27, 2020 On 10/24/2020 at 6:48 AM, desertfish said: Also, I would have expected that using ".import byte_to_hex_ascii " would enable you to use the symbol rather than the absolute address; but, that doesn't work. I'm not familiar enough with the tool chain to come up with a possible solution for that. Is there someone else that can? I think that referring to the absolute address of the function is quite brittle. Every ".import name" must be matched by a ".export name". In this case, "monitor.s" should contain.export byte_to_hex_ascii Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 27, 2020 (edited) I believe I tried that without luck... ... Just tried it again, still no luck. in monitor.s: .export byte_to_hex_ascii in x16additions.s: .import byte_to_hex_ascii ... Still it does not recognize the name. Edited October 27, 2020 by JimmyDansbo Quote Share this post Link to post Share on other sites
Greg King 50 Posted October 27, 2020 I looked at the makefile. Unfortunately, the ROM banks are built separately, nowadays. They can't know about each other's labels. Jump-tables in unchangable locations would need to be used to share subroutines, reliably, from other functional modules. Quote Share this post Link to post Share on other sites
desertfish 172 Posted October 27, 2020 Sounds to me as if copy-pasting that particular routine from the monitor is the way to go.... (personally I would prefer that over a suddenly crashing ROM because the monitor was modified and the routine is no longer on the hardcoded address) Quote Share this post Link to post Share on other sites
JimmyDansbo 66 Posted October 28, 2020 7 hours ago, desertfish said: Sounds to me as if copy-pasting that particular routine from the monitor is the way to go.... I agree. Now that some space has been freed, I will look into getting the byte_to_hex_ascii function back into the BASIC rom and I will tidy up the HEX$ and BIN$ functions as I had to jump through quite a lot of hoops to make the fit before. 1 Quote Share this post Link to post Share on other sites
