I am trying to understand how PS2 keyboard output is read by the CommanderX16.
From my understanding the data and clock pins of the keyboard is connected to VIA2 pins PA0 and PA1. Initially I thought that the VIA would fire an interrupt when the clock changed which samples the data pin. But glancing over the datasheet of the 65C22 I don't see the possibility to generate an interrupt if the clock pin (PA1) would change. Maybe the clock is also separately connected to an interrupt pin? If not, then I guess the keyboard is not interrupt driven?
Next I tried to read the kernal keyboard driver code but my assembly skills are a bit limited. Looks like clock (PA1) is held low which prevents the keyboard from sending data. When the program want to read the keyboard it releases the clock line and then starts to sample the data and clock pins until the whole scancode was read. But this would mean that when the program wants to check for a key press it will block until the user presses a key which also does not sound correct?
Does anybody have some insights on how this works?
Hi everyone,
Share this post
Link to post
Share on other sites
