Syntax: S "<file-name>",xx,yyyy,zzzz
xx = device number 01 for tape 08 for disk
yyyy = the start location of the program
zzzz = the end location of the program + 1
I tried to save memory location $2000 to $2100 to disk, below are my attempts:
Attempt1, assume, device is 8
S "TST",8,2000,2100
fails, output -> S "TST",8,?000,2100 (see the ? sign in the output on the left)
Attempt2, assume, device is 1
S "TST",1,2000,2100
fails, output -> S "TST",1,?000,2100
Attempt3, assume, device is not needed
S "TST",2000,2100
fails, output -> S "TST",20?0,2100
So I assume the second param must be the device, as well on the X16, but I am not sure which. Since attempt 3 marked the second param as wrong.
So I tried from 0 up to 9, no differences.
Then I maybe the syntax of the start address is wrong.
Attempt4, assume, address starts with $
S "TST",8,$2000,$2100
fails, output -> S "TST",8,?2000,$2100
Then I was thinking maybe param nr 3 is a string, so I tried as well, and what about if the addresses are supposed to be "large" addresses, which I tried as well.
Hi!
I hope I am not repeating and old question, but I am just getting into the X16, and I did search the forums, and found no answer.
I am trying the monitor "MON", inside the X16 emulator, to write a rudimentary assembly program.
However I have issues with the "S" command.
I checked the syntax for the save (S) command over here: https://rr.pokefinder.org/rrwiki/images/7/70/Final_Cartridge_III_english_Manual.pdf (search for THE MONITOR [12.0] )
S "TST",8,2000,2100
S "TST",1,2000,2100
S "TST",2000,2100
No luck so far. Any help appreciated!
Thanks
/C
Share this post
Link to post
Share on other sites
