X16 visual novel games?
xanthrou
Post by xanthrou »
Is it possible for anyone to make an PC-98 style visual novel for Commander X16, since VERA is theoretically capable of doing 256 color graphics?
Lorin Millsap
Post by Lorin Millsap »
Yes and no. Using 256 color mode is unlikely unless your resolution was really low or you figured out how to do it in tile mode. In reality you’d probably drop the color depth and resolution.
AndyMt
Post by AndyMt »
If you stick to 320x240 in 256 colors - yes that's possible - but challenging. I've done it in Invaderz for the background graphics, which all use around 200 colors (the rest goes to the sprites of player and enemies). Thing is - in the emulator, loading the bitmaps takes almost no time. But it will be slower on real hardware, roughly 2 seconds per screen when loading from SD card. Using compression techniques might not mitigate this, as unpacking will use CPU time... Unpacked, each screen takes around 76kBytes of data.
SlithyMatt
Post by SlithyMatt »
I've created an adventure game engine for the X16, like Sierra's SCI or Lucas Arts' SCUMM, but I am using 16-color graphics. However, since you can have custom palettes, the results are much nicer than the EGA games you may remember. Here's the intro to a game I'm developing for that engine:
And a bit more of the game:
Gold
Post by Gold »
PC-98 games generally only had 16 colours available, so it would be most faithful to stick to that anyways.
xanthrou
Post by xanthrou »
Especially early ones.
Though in a japanese style visual novel, if the bottom third of the screen is reserved for text ... now 320x160 ... and most in scene changes happen in a foreground while the scene background is stable ... so in scene changes are in the upper bitmap layer in a 160x120 section centered in the 320x160 lower bitmap  ... preloading from the SD card into three High RAM banks while the player is reading and loading to Vera from HiRAM would make in-scene transitions pretty snappy.
xanthrou
Post by xanthrou »
Thanks! That way it is certainly possible to do PC-98 style VNs.
But uh-oh though, if that works well for the most time, someone is gonna go and develop a naughtier VN for the X16 like the PC-98 had many of them.
