Portable power supply for X16.
Re: Portable power supply for X16.
1:36 pm.............. Still playing. Made the 4 hour mark on the Battery . So > 1 hour per Battery Ah.. at least. Means if I plug in a 9ah Ryobi Battery I should get damn near 1/2 day of run time.
Are you posting from the future? Msg. post time = 1:08, stated time = 1:36.ahenry3068 wrote: ↑Tue Sep 26, 2023 5:08 pm 1:36 pm.............. Still playing. Made the 4 hour mark on the Battery . So > 1 hour per Battery Ah.. at least. Means if I plug in a 9ah Ryobi Battery I should get damn near 1/2 day of run time.
Probably not the future.... Probably just dyslexia
Just now............ still playing
I'm running until battery death...... Hope it doesn't corrupt my SD
Hanging on at just 1 bar on the battery, actually much longer than I had hoped. At the moment still playing
Welcome to Death Row Battery!ahenry3068 wrote: ↑Tue Sep 26, 2023 5:28 pm Hanging on at just 1 bar on the battery, actually much longer than I had hoped. At the moment still playing
It did finally die............ I missed the moment.
I restarted just now with a fresh battery
STARTING PORTABLE BUILD
Ok. Back here after more than 3 mos. This is why I built the Power supply.
I have every thing together for my portable build. Now it's just logistics. I have to figure out how to mount everything and get it all in the DeWalt Tough Case.
Going to start another thread and put a link to it here:
Portable luggable build
viewtopic.php?t=7084
