This example program in ROM BASLOAD format has 5 very useful GOSUBS and a useful FUNCTION.
In this code the "Directory Stack" is a Bank of Hi-Ram. I'm using 63 in this example code but it could
be any available Bank. Contained in the Variable Dir.Stack
If your code needs to access multiple devices its also written so you could swap out Stacks You would need to save the values of the variables DEVICE, Dir.Stack, and Dir.Ptr and Dir.Level (all REAL numbers). Set Dir.Stack to a different Bank, Set Dir.Level to 0. and set DEVICE to the New Device #. Call GetCWD again. Then you have another Stack for the New Device. You should call GetCWD after each DEVICE Swap
DEF FN SW(X)
Takes X between -32768 and 65535 and converts it to the corresponding "Signed Value"
between -32768 and 32767 so that AND & OR can be used on it or it can be assigned
to an INTEGER. Bitwise ANDs and ORs only work in BASIC correctly on signed values in
that range. Error if X<-32768 or X>65535
GOSUB GetCWD
Populates the variable CWD$ with the Current Working Directory.
GOSUB PUSHDIR
GetCWD needs to be called prior to first call to PUSHDIR. If using this
procedure you need to use ONLY this procedure and POPDIR to navigate
the Directory tree. Prior to calling PUSHDIR, set the variable New.Dir$
to contain the Directory to CD to. Upon calling it saves the Current Directory
position on the "Stack" and CD's to New.Dir$. CWD$ is correctly
populated before RETURN.
GOSUB POPDIR
"POPS" The previous Directory off the "Stack". CWD$ is correctly
GOSUB POKE.STRING
Stores the String Variable S$ at the address contained in Variable SAddr
Stores the string Data "Pascal" style with length byte followed by string data.
GOSUB PEEK.STRING
Returns the String at SAddr
(previously stored with POKE.STRING
(or possibly other PASCAL style string))
returns the value in S$
HERES THE CODE:
PUSH DIR & POP DIR IN CBM BASIC
Return to “Libraries and Examples”
Jump to
- Forums
- ↳ Official Announcements
- ↳ X16 Bug Reporting
- ↳ Introductions
- ↳ Commander X16 Forums
- ↳ Rules & Policies
- ↳ CX16 General Chat
- ↳ Programming
- ↳ How-To
- ↳ CX16 Hardware Support
- ↳ X16 Software Support
- ↳ X16 Feature Requests
- ↳ Website Feedback And Support
- ↳ Murray2 CX16 Discussion Archive
- ↳ Works In-Progress Discussion
- ↳ Libraries and Examples
- ↳ Lounge
- ↳ General Retro Chat
- ↳ Creative Arts
- ↳ Maker Projects
- ↳ Memes
- ↳ Modern Computing
- ↳ Off Topic
- ↳ Help Wanted
- ↳ Trade, Buy, Sell
- Downloads
- ↳ Official Software
- ↳ Games
- ↳ Productivity Apps
- ↳ Graphics Apps
- ↳ Audio Apps
- ↳ Development Tools
- ↳ Libraries And Demo Code
- ↳ Emulation, PC Connectivity, Networking
- ↳ Misc Apps
- ↳ Tutorials
- ↳ Demoscene
- ↳ WIP Demos
- ↳ Archive
- ↳ Program Requests, Suggestions, Ideas
- ↳ Monarch Open ROM
- ↳ Video/Podcast talk
