Funkheld
6502 CPU only has few registers... Accumulator (often called A), X and Y.. each is 1 byte - 0 to 255..
Multiple instructions allow indexing into memory using X or Y register ...
Actually, I gave some example of that in the other forum post, where you had asked about prog8 to save/load the current screen..
This bit here - uses X as a counter to track pages, y to index each byte of the page, and ZeroPage_PTR is 2 consecutive bytes in zero page of RAM ( $0000-$00FF ) set to some address like $HH00... the start of a page of memory..
LDX #num_pages
LDY #0
: LDA DATA0
STA (ZeroPage_PTR),y
iny
BNE :-
INC ZeroPage_PTR+1 ; this bit right here or you'll only keep overwriting that first page you're trying to write too.
DEX
BNE ;--
random index into array > 256 requires altering the highbyte... one _could_ create an array of arrays to manage the high byte themselves... IE say for 60 lines on screen, make an array sized 120 (60*2 bytes) to hold pointers to arrays with 160 bytes each (80 characters across the screen, char code + color data )
Then ... what line do you want? ... say 31... double it => 64 ... get bytes 64 and 65 into your pointer / memory address ... that would be the array to index for the other data ..
or if the arrays always start at beginning of page, would only need 1 byte for the first array, and access via the setting some ZP to $HH00 to index... but in this example, that would waste 96 bytes per line in memory...
(that bit -might- be more for desertfish to consider supporting a '2d' array of X pages... maybe in a way to span banks??? they are writing a compiler alone... it may be a bit much to ask )
I had provided some code for saving/loading the screen - maybe someone here could fill in the vars and such I wasn't sure on??
viewtopic.php?t=7266
sub screensave() {
ubyte *SAVEDSCREEN $someaddress_in_RAM ; // set the pointer here
for y1 in 0 to 60 {
cx16.vaddr_autoincr(1, VERA_TXTSCREEN + y1*$0100, 0, 2)
for x1 in 0 to 79 {
*SAVEDSCREEN = cx16.VERA_DATA0;
SAVEDSCREEN++;
sub screenload() {
ubyte *SAVEDSCREEN = $someaddress_in_RAM ; // set the pointer here
for y1 in 0 to 60 {
for x1 in 0 to 79 {
cx16.VERA_DATA0 = *SAVEDSCREEN ;
SAVEDSCREEN++;
Hello, thank you very much for the quick information.
Now I'm going to go to sleep and I'll work on it tomorrow.
Thank you.
greeting
Thank you.
greeting
Prog8 version 10.2 released
Prog8 version 10.2 has been released
https://github.com/irmen/prog8/releases/tag/v10.2
The most important change is that the compiler now treats booleans much stricter than before. No longer 'equivalent' to a byte 0 or 1. You'll need an explicit cast to convert between bytes and booleans now.
If you are using conditionals like "if integervariable {....}" you'll have to make it into a boolean comparison expression like so "if integervariable!=0 {....}" .
For all the gory details read the release notes on the github release page.
hello, thank you for version 10.2
What a great job you're doing, great.
Thanks.
greeting
Thanks.
greeting
version 10.2.1
Prog8 version 10.2.1 is released https://github.com/irmen/prog8/releases/tag/v10.2.1
Unfortunately a rather severe error was found after the 10.2 release, in the code generator for logical expressions (and/or). This is now fixed.
PS the error was already present since version 10.0, just not discovered until now...
hello thanks for info.
greeting
greeting
version 10.3 released
Prog8 version 10.3 has been released: https://github.com/irmen/prog8/releases/tag/v10.3
There's a change in this version that's not backwards compatible with older code, so it may be required to make some simple changes:
It is now possible (and required) to assign all values returned from a romsub/asmsub that returns multiple values.
The void keyword can now also be used in a new way: as a dummy assignment target for any value you are not interested in in such a multi-value assignment.
Please read the documentation in the manual for details about this new feature: https://prog8.readthedocs.io/en/latest/ ... ultiassign
hello, thank you for the new version.
greeting
greeting
This is such a great project. Thank you!
