"Hello, World!" with cc65
SlithyMatt
Post by SlithyMatt »
2 hours ago, kliepatsch said:
. To me, the 2061 still seems like a magic number. Where does it come from?
2061 = $080D
It's simply the start of the machine language program. Before that is just tokenized BASIC and the CPU would choke trying to run that directly, instead of with the BASIC interpreter.
geek504
Post by geek504 »
45 minutes ago, SlithyMatt said:
2061 = $080D
My hello.asm does a byte by byte commentary on these magic numbers before your assembly code:
; cl65 -o hello2.prg -t cx16 -C cx16-asm.cfg hello2.asm
; Also, you should count on CHROUT modifying X, so you should flank that jsr with phx and plx.
; Run with x16emu.exe -prg hello2.prg -run -scale 2
    .org $0801                  ; Assembled code should start at $0801
                                ; (where BASIC programs start)
                                ; The real program starts at $0810 = 2064
                                                 ; 10 SYS 2064
    .byte $0C, $08                    ; $080C - pointer to next line of BASIC code
    .byte $0A, $00                    ; 2-byte line number ($000A = 10)
    .byte $9E                             ; SYS BASIC token
    .byte $20                             ; [space]
    .byte $32, $30, $36, $34   ; $32="2",$30="0",$36="6",$34="4"
    .byte $00                             ; End of Line
    .byte $00, $00                     ; This is address $080C containing
                                                  ; 2-byte pointer to next line of BASIC code
                                                  ; ($0000 = end of program)
    .byte $00, $00                     ; Padding so code starts at $0810
    CHROUT = $FFD2
    ldx #0
again:
    lda hello, x
    cmp #0
    beq done
    stx SaveX
    jsr CHROUT
    ldx SaveX
    inx
    jmp again
done:
    rts
SaveX: .byte 0
hello:
    .byte   "hello world! ", $00
Enjoy!
SlithyMatt
You can lose that CMP #0 instruction. It's unnecessary. The LDA before already sets the Z bit the exact same way.
geek504
Post by geek504 »
Point noted, just as the stx/ldx SaveX could be replaced by the most efficient phx/plx to save a few bytes more. Sometimes a more verbose code explains better than an efficient code ? Efficient code sometimes look like magic!
MontyHall
Post by MontyHall »
I can't get hello world to work.  I'm running ubuntu 20 and compiled cc65.
When I make I get the following:
(base) rick@rick:~/workspace/x16-hello-cc65$ make
make -C asm
make[1]: Entering directory '/home/rick/workspace/x16-hello-cc65/asm'
cl65 -t cx16 -o HELLOASM.PRG -l hello.list hello.asm
ld65: Error: Cannot find config file 'cx16.cfg'
make[1]: *** [Makefile:4: all] Error 1
make[1]: Leaving directory '/home/rick/workspace/x16-hello-cc65/asm'
make: *** [Makefile:2: all] Error 2
I have cc65/bin in my path. I suspect I need to hack the make file to point to configs.
MontyHall
Post by MontyHall »
What's the performance penalty of using cc65 C over pure assembly?  Have to admit would like to rapid prototype in C w/o the assembly albatross.  Would you say cc65 C is 2x slower?  It certainly can't be worse than basic 2.0.
It should be way way faster than basic.  Some micro benchmarks comparing several languages (including raw assembly)  is here https://github.com/KarolS/millfork-benchmarks/tree/master/6502
MontyHall
Post by MontyHall »
That's impressive.  Reasonable hit in speed using cc65 C.
geek504
Post by geek504 »
Just don't do a printf() version of "Hello, World!" That'll generate a binary of at least 2,000 bytes! Use CHROUT or STROUT instead with assembly or C using a specific X16 library.
geek504
Post by geek504 »
You need other directories defined as well... here's my Windows batch file I run before compiling with cc65:
set CC65_HOME=c:\cc65
set CA65_INC=c:\cc65\asminc
set CC65_INC=c:\cc65\include
set LD65_LIB=c:\cc65\lib
set LD65_CFG=c:\cc65\cfg
set LD65_OBJ=c:\cc65\obj
set PATH=%PATH%;c:\cc65\bin
