Story time!
So, I'm running an
XFX RX 580 DD 8GB card in my system. It does what I need it to do, even though the 580 line has been out since 2017 and was technically a "refresh" of the 480 line . Had it about 2 years now. Was under $200 when I got it, before the silicon hit the fan and sky-rocked in price.
About a year ago a fan started making noise, and XFX kindly sent me a set of new fans and a shroud. So I tore the card apart and replaced it, and in the process I had to replace the thermal compound as well. Put it all back together. Worked great.
Fast forward to this past week, and I start putting it under heavy load for the first time in months. Temps are pushing 85C, got the fans cranked to 2300+ RPM, so it got loud and hot. Started under-volting it to drop the temps, got them down about 5 or 6 C to just under 80, but still too hot and loud. It was running at 65C to 70C max, under full sustained load.
So... tore it apart again. Thermal compound was hard...it dried out, I used my tried and true Arctic Silver 5. Dug out the tube, checked it out, it's barely still pliable, and I picked it up new a year ago when I replaced the fans. Guess I got a bad tube, or one that sat in a warehouse forever. So, I just got 2 tubes of Arctic MX4 recently, and I like it better anyway. Put that on there and...
65C under max sustained load at 1600'ish RPM. Cool and quiet! Even more so than it was originally!
On a side note, I did discover my card can under-volt to 1050mV and remain 100% stable, at stock it runs at 1140mV under stage 7 (max) load. May see if I can get it under 1000mV, I know some cards can, seen some people saying they got them running at about 960mV.
Lower temps, lower RPM on the fans, a win win out of an annoying situation!
Amazes me how much heat modern hardware produces sometimes, but the level of control they give you over it is so nice.
? This is my card, love the look of it as well as the performance for the MSRP. NOT the current prices of hardware. These cards are going for $600 new right now. NOT worth it! lol
