DreamTracker Dev Log
Re: DreamTracker Dev Log
Heheheh 90's eurodance. I wasn't a fan at the time, but have to admit it's kinda cool to hear it in this form
DreamTracker 0.68 is out! This is the Infinite Scroll edition! Not too much else obvious to the user, though lots under the covers with the module loading re-org and converting the UI elements to be drawn programmatically. This is most visible in the new (but not yet necessarily better) loading and help screens. Some bugs crushed too but mostly it's the kick-ass pattern scroll stuff. Download link is in the first post (dreamtracker.org).
While I had planned on having the next version of DT out soonish, I decided to go full steam ahead into the effects reorg and have been making changes within a branch just in case folks are building from source and/or I need to do any minor fixins to the current release.
The next release will have the effects reorg changes. Many of these are in the docs within the branch but you can see them here as well. Additionally I have been changing out the static screen buffer files for drawing the display more programmatically which is both faster and makes things easier for me to change things around without quite so much toil. This required updating some of my printing functions to be a bit more intelligent which took some time. I'm also trying to crush some long standing bugs, such as lack of error reporting / freeze if you try to load a file that doesn't exist. Stuff like that.
Back to the reorg, now that I have loadable modules, that means I have a lot more code space. Previously I was worried about adding non-essential or one-time use code to DT for fear of running out of RAM. That's much less of a problem now and, as such, I will now have in-app file-conversions. That means if you load an older song, DT will convert it to the current song format. It won't be the fastest operation but this both presents a decent user experience while allowing the DT file format to change and grow more organically without breaking compatibility.
All these changes I think are enough for me to perhaps consider making the next release of Dreamtracker the first Beta release which would be a huge milestone. Beta doesn't necessarily mean it's feature-complete (noting tables/macros are still planned). Just that it's solid enough that I don't expect file breaking issues between versions.
Anyways the gap to the next release given all of the above and some travel I have coming up might be a bit longer than it has been lately but I think it'll be very much worth it!
Oh don't worry, there will still be plenty of breaking things
Alright just a quick update for folks that wanna try it out. It's not "released" yet (as in it's not the main download link off dreamtracker.org) but here's a pre-release / work-in-progress of version 0.69, hopefully the last alpha, which contains the effects reorg and song conversion:
https://www.dreamtracker.org/downloads/ ... .69-pr.zip
Announcing Almost Beta! Maybe. Sort of.
DreamTracker 0.70 Pre Release 2 is out and you can find it over on dreamtracker.org!
I'm hoping 0.70 will be the first beta release and while 0.70 itself is getting reasonably close, there have been some huge changes underneath. Notable the effects have been reorganized to better suite future expansion and sharing effects inherent to 2 or more sound sources while also giving effect space for dedicated per-source effects. I've written a conversion routine that will remap effects in older songs so no problem there.
But I also changes how the vibrato, pulsolo and tremolo effects work. I think for the better! But I haven't yet updated the conversion routine and even when I do it won't be perfect due to how the effects now work. Part of Beta is a (hopeful) goal of not introducing big changes like that. So here's hoping it's the last one. Where I do make big changes, I will leverage the conversion routine setup. So while I can't fully guarantee full compatibility, I will commit to converting songs to the newest format as best as is reasonable.
In addition to this, note delay, finetune, and legato are now available pattern effects, some more keyboard shortcuts exist and numerous bugfixes.
To hear some of the new changes, download the newest version and load up CAVE.DTR. Or you can listen to it here:
