Towers of Hanoi in BASIC
MarkTheStrange
Post by MarkTheStrange »
Thought this would make a relatively simple demo of what you can do with BASIC. It loads some sprites into memory and draws some pegs and then animates the solution for the 8-disc Towers of Hanoi puzzle. The solution part uses recursion via global arrays functioning as "stacks" for each "local" variable.
hanoi.bas
(29.73 KiB) Downloaded 240 times
hanoi.prg
(9.81 KiB) Downloaded 287 times
Last edited by MarkTheStrange on Wed Apr 17, 2024 9:21 pm, edited 1 time in total.
Re: Towers of Hanoi in BASIC
Ah, an olde but a goodie. I remember seeing that program back in the '70s when I was using a Decwriter.
