I previously requested users to test a demo in progress using actual hardware, and there were issues with rendering and the joystick. The rendering issue was traced to a problem in VERA, so that leaves the joystick.
After some research, I think the issue was that I was using JOY_1 as the joystick to read, and my understanding now is that this is mapped to the keyboard as an emulated joystick. I think JOY_2 might be the one that connects to the actual joystick port. The documentation isn't 100% clear on this.
I've written and attached a short program JOYSTICK.PRG to confirm. If someone can run it and try it out, that would be great. Basically I mapped the digits 1, 2, 3 to JOY_1, JOY_2, and JOY_2 + 1 (doesn't appear to be a JOY_3). So you can type 1, 2, or 3, then try out the joystick. If the code is reading from the joystick, there should be a lot of diagnostic output.
If it works, can you let me know which of 1, 2, 3 you used? I need only the left port, but if you want to try the same with the right port, that's great, too.
I'm also going by some images I found on the web of the CX16 hardware, if the ports are actually vertically aligned, then please substitute top and bottom for left and right.
Thank you,
Russell
Request to try out joystick interfacing program
JOYSTICK.PRG
- (1.67 KiB) Downloaded 184 times
Re: Request to try out joystick interfacing program
There's a header on the motherboard for hooking up a third and fourth controller. But systems that have those wired up are likely to be pretty rare.
i have tried it, there is an offset:
when i push 1 i get joy(0) the keybord
when i push 2 i get joy(1) port 1 controller
when i push 3 i get joy(2) port 2 controller
Thank you very much for testing. I was confused by how CC65 labels the joysticks vs how CX16 labels them. It was only when I read a similar thread in one of the forums here that I figured out that CC65 JOY_1 refers to the keyboard emulator. I'm waiting now for a fix to the VERA FX Line Helper in 4 bpp mode. /Russell
